MFL
Jun 22, 2022Nomad II
Grit dog wrote:blt2ski wrote:
Now that I've reread intial better....
If the gas rigs are pre 2014, assuming a 6.0 gas, I would not buy that rig, 2500, 3500 SW or dw! A 6.6 gas is a way better option power wise. If at elevations below 6-7k' best. It will go to the 10-12k feet elevation in Rockies, but your down 30% of HP at those levels. If a single life time trip, go fo for it, if ALL the time over next 3+ years, get one of the diesels from last 10-15 yrs.
An ext cab may be ok payload wise, depending upon options 6.5 bed is 200 LS less than an 8' bed. The longer bed and wheelbase may be better than the loss of payload.
Marty
What’s the aversion to pre-2014? Same power and 6 speed back to at least 2010 as I recall.
I know the body/chassis updated in 2015 if that’s what you meant. But I’m not aware of any major chassis capability changes.
Regardless, OP shouldn’t even consider unless 4.10 gears.
IIRC, 2014 was the year GM 2500 6.0 went to 4.10 gearing as standard, since earlier standard was 3.73.
Jerry
