Bobbo
Aug 05, 2017Explorer III
What was Airstream thinking?
Just because Airstream didn't think the 2017 Flying Cloud 23FB needed 12v outlets doesn't mean I think it doesn't need them! (I leave it laying at the bottom, back of the wardrobe till I need it.)
The 12v outlets came with a 15 amp inline fuse on 18g wire. I cut off the inline fuse since I wired it to an empty slot on the 12v distribution board with a 15 amp fuse. I cut the 18g wire as short as I could and butt connected it to 12g wire (seems like that is all Airstream used, the wide spot in the wire right in front of the shelf are the 2 butt connectors, staggered so they are not too wide). Like I said, I ran the hot wire to an empty slot on the 12v board, and ran the ground wire to the ground wire buss in the 120v side of the breaker panel (be sure NOT to use the neutral buss). The 120v ground buss is connected to the 12v ground. The wardrobe that it lives in is only about 2 feet from the breaker panel/fuse box and on the same side of the trailer.
