BenK
May 07, 2019Explorer
EV 'cars' that meet my personal criteria might happen within my lifetime, but don't think TV's will...
Have bee in love with electric cars since my first career in solid state, variable electric motor controls working my way through college. Circa late 1960's through 1980's.
But...the storage is still not there yet. Until then, ICE's will be my preference and why am planning to rebuild my 7.4L Suburban
It takes about 10-15 minutes to fill my almost empty 42 gallon gasoline tank. Like electric storage (no matter batteries, capacitor battery, etc) will take hours and hours on fast charge, which shortens the battery life.
Or carry 5 gallon Jerry cans, which to date, as no comparable battery pack. Maybe batteries underneath any trailer I might purchase in the future, but have found nothing yet
A good design battery system (electric motor and the biggie, the controller) will/can have that motor produce 100% rated torque at ZERO rpm and if the controller is designed to produce more (our industrial controllers would allow up to 300% for short periods, but our customers required 100% duty cycle 24/7).
The why of wanting 5.38's (want higher numeric, but couldn't find any I like) and a GearVendors OD, which will turn my 4L80E into an 8 speed with a double OD. It will be close ratio setup and have a 1st gear comparable or even lower to almost any other tranny's 1st gear. Add the transfer case and my Suburban will have a 16 speed setup, but can't shift the transfer case while moving like the old days...fashion statement crowd has the OEMs design them to be shifted from a standstill
Used to be able to smoke the stock tires (ordered the Suburban with 4.1's) and when towing, had to let off the throttle in order to save the tires
Les, that cam is also known as a RV or the last time built an engine...a 280 cam. It should have around 50% rated torque just off idle and full rated torque around 1,600 RPMs. With a red line around 4K RPMs...maybe a bit more if higher rate valve springs and roller everything in the valve train, but that is a rarity these days for a big block.
Pie in the sky wishful stuff would be direct injection and that the Army would release for public their next gen tank electric motor found while consulting on something. 1,400 HP at 480Vots and about the size of a basket ball (liquid cooled) that would fit in the tranny tunnel to empty the engine bay
{edit}...guess that tank motor is no longer, as the web site doesn't list it anymore
Tank motor
{2nd edit}...just had to double check and did find that they still have that next gen Army tank motor listed...just buried a bit farther in their web side
High Torque Density Traction Motor
Tank motor
I've used some locomotive traction motors back in the 70's for a log
mill controller. That thing was about 6' in dia with a solid steel
shaft about 8" in dia.
Locomotives use electric traction motors as their main drive and a
diesel generator to supply it along with batteries.
A few years ago consulted on the next gen Hybrid and looked up traction
motors thinking electric is around the corner. Found this one:
Electrodynamics Associates 1500 HP traction motor
187 HP at 600 rpm
375 HP at 1200 rpm
750 HP at 2400 rpm
1500 HP at 4500 rpm
This one is still a proto type for the next gen tank.
It is small enough to go into our light duty trucks, but will be too
expensive. So it's little brother will apply.
Since 'some' electric motors can be over driven (think of Nitro
injection that the dragsters use on an internal combustion engine, ICE).
Since it has so much toque at the low end, won't need a tranny of any
kind. Transmissions are needed by ICE's because they have such low
end torque, even a diesel. Why locomotive is electric to get them
going (engine weighs in around 400K-500K lbs, plus the other cars).
So small it can fit in the space where the tranny 'used' to be.
Agree with you that the battery is now the limiting component/system.
But that will be solved soon enough, or just live with tons of Optimas
for a while....
electrodynamics wrote:
Developed under contract from the U.S. Army TACOM, the motor is of a pancake type design with water-cooled stators.
The controller design is based on hysteretic switching of input current. Water cooled power IGBTs have control signals transmitted via fiber optic cables to prevent adverse effects of electrical interference.
Breadboard assembly and tests with partial loads have been completed.
Details:
Motor Diameter: 25 inches
Length: 10.5 inches excluding shaft
Speed.RPM...Continuous HP....DC Bus Voltage
4500...............1500..............1200
2400................750...............600
1200................375...............300
600.................187...............150
Note: Other speed, torque and voltage combinations available.
44,071 PostsLatest Activity: Aug 30, 2026
