Terryallan
Aug 21, 2013Explorer II
agesilaus wrote:
Then the TT shouldn't weigh more that 4K probably. U-Haul will install a receiver for you. And a plug for the power. You can buy a ball mount and ball from them or get it from eTrailer.com online, or at a local Tractor Supply. Make sure the ball is rated for 5K which shouldn't be a problem.
link
I'd get the dealer to install a Prodigy brake controller. It should be a simple plug in and installation of the mount with a screw or two. They should throw in the installation with the cost of the controller and TT.
As for sway control, you can try a friction type:
sway control
I don't know if you'll need a full blown WDH for a TT that light.
BK
NO Do NOT let U-Haul touch it. You plan to let the dealer do it is best.
