albert18
Jul 10, 2023Explorer
Hey, when it comes to sewer hose storage, there are a few options you can consider. One solution is to use a piece of PVC pipe attached to the rear of your trailer. Based on your measurements, a 4.5" PVC pipe should work for storing your new Rhinoflex 15' hose. While most RVs have 4" rear bumpers, using a slightly larger PVC pipe should accommodate the hose with connectors.
If you don't have a bumper on the rear and only have 1/2" square tubes, you can still attach the PVC pipe to those tubes or explore other mounting options. Keep in mind that adding a small rack in the future may require some adjustments, but you can address that when you're ready.
As for cost-effective alternatives, you could also consider using hose storage solutions specifically designed for RVs, such as collapsible hose carriers or storage bags. These options might provide convenience and ease of use while keeping your sewer hose secure.
I hope this helps, and if you have any further questions, feel free to ask. Safe travels and enjoy your camping adventures!
44,071 PostsLatest Activity: Aug 30, 2026
