trailernovice
Feb 01, 2016Explorer
What's the advantage of the frame design on our new TT?
Our past travel trailers have had a 'straight' frame...by that I mean the coupler and its framework just continued straight from the main part of the frame...
on this trailer, the A-frame ending with the coupler is mounted under the main frame rails...
I can tell the frame on this unit sits considerably higher than what we've had in the past...ex. the front stabilizers on the last unit needed only 20-25 'cranks' to be firmly seated on the ground, whereas the ones on the new trailer need more than 50...the difference is also apparent visually...
truth to tell, didn't even take notice of this until the trailer was bought and the paperwork done (i know, i know...should have realized)...
It would seem to me that this configuration, with the coupler A-frame welded to the bottom of the frame rails, creates a potential failure point where the coupler frame meets the main frame rails...am I just paranoid?
Are there any advantages to this sort of a frame, other than the obvious increase in ground clearance?
