- westendExplorer
Bumpyroad wrote:
From the technical data sheets, Sikaflex 227 is superior to the 505 product for RV applications. The 505 is formulated to have better adhesive bonds to different materials like stone and plastic.westend wrote:
Ruthless wrote:
Does anyone use:
CW 221 SEALANT SIKAFLEX 10.3 OZ
or
WHT 505 SEALANT UV HV SIKAFLEX
I've used Sikaflex for construction applications. Both of the Sikaflex products you listed (227, BTW) are urethane based polymers. The first one is the most applicable for RV use but it has less elongation and tensile strength than the Geocel products. It will work but in your context of this thread, is not "the best".
gotta check my owner's manual again but I think I need a urethane type of sealant. are you indicating that the second one 505 would be preferable to the 221? I did find a 3M white sanded polyurethane caulk if anybody has any experience with that.
bumpy
For our RV's it would make sense, IMO, to have the most durable product with the best elongation and tensile strength. The Geocel tripolymer products seem to have the better ratings in those areas. There are other things to consider, though, like tooling and paint adhesion. When I'm shopping for products like these, I mine the data sheets and the MSDS to find out how they are made and what separates them from others. It's the little scientist locked inside me, I guess.:B - BumpyroadExplorer
westend wrote:
Ruthless wrote:
Does anyone use:
or
bumpy - clubhouseExplorerIf the sealant will touch the roof membrane in any way make sure you know that roof material in advance and what can be used on it.
I have the new Alpha-ply TPO roof membrane...Dicor will cause it to react and blister. - westendExplorer
Ruthless wrote:
Does anyone use:
or
I've used Sikaflex for construction applications. Both of the Sikaflex products you listed (227, BTW) are urethane based polymers. The first one is the most applicable for RV use but it has less elongation and tensile strength than the Geocel products. It will work but in your context of this thread, is not "the best". - RuthlessExplorerDoes anyone use:
or
WHT 505 SEALANT UV HV SIKAFLEX - donandmaxExplorerYeah, Dicor best I ever used.
- westendExplorerI use Geocel 2300 Tripolymer. It is similar to the Proflex product but has better adhesion, elongation, and tensile strength. It's also available, locally, through a roofing distributor.
The newer Geocel 2300 MHRV is probably one of the best sealants for a moving vehicle. It is not good with EPDM so if a roof flashing sealant is needed Dicor would probably be a good choice. Geocel also makes an EPDM sealant but I've never used it. - badboy368ExplorerPRO-FLEX for sure
- WoodGlueExplorerI should add, if it's a rooftop application, you'll want to seal with Dicor Self Leveling Lap Sealant, if it's on the sides, that's the GeoCel Proflex.
WoodGlue - WoodGlueExplorerGeoCel ProFlex. Caulk the screws before you put them in and then over the top too!
WoodGlue
44,066 PostsLatest Activity: May 18, 2026
