jaycocreek
Oct 21, 2018Explorer II
If I put the 350lbs into a trailer, is it better or worse, given the trailer has its own weight addded to the GVWR?
GVWR don't mean much in your situation but axle capacity does, when towing with a AF 811.As far as I can tell the AF 811 already puts about 7500(Total weight) or so pounds on the rear axle and adding a trailer ads more weight on that rear axle...
If your rear axle is rated for over 8K,go for it...Actual axle rated weight by the manufacturer, not the door sticker.
