Jayco-noslide
Nov 10, 2014Explorer
We've spent a number of nights down around 20 and this isn't a huge problem as long as your furnace works OK. But it's not without problem. For example, you can't hook up to water because your hose will freeze solid. Just make sure your storage tank is full. Also, your valves will be frozen in the morning so that you can't dump your tanks. We've survived OK down to 7 degrees with wind but then all outside faucets in the campground froze and some broke so could only get water from inside a heated building. Never would do it on purpose.
