valhalla360
Nov 11, 2014Navigator
davisenvy wrote:
Will filling up the onboard water not freeze? My water pump is under the sink, so I'm fairly confident that won't have any problems. I just don't understand why the onboard water is less likely to have problems.
It depends on how your systems are laid out. Some cold weather specifc RVs will deviate but typically:
The fresh water tank is in an enclosed space and will be several degrees warmer than outside. As long as it doesn't get extremely cold, it will stay unfrozen.
Gray/Black tanks are usually set lower so the drains can reach them via gravity and are frequently fully exposed to the outside air temp and windchill effects.
