Passin_Thru
Jul 27, 2015Explorer
Funny! Looking at my Arctic Fox 31 W. It has a 3 in dia bearing inside and outside of ea axle, holding around 4 K on ea axle or 2000 lb/ side or 1000/ bearing sitting still. Figure in side loads, the pressure of a 2000 lb loading meeting asphalt (Well, with a small seperation) and the added temperature of a 120 degree day in the Mojave, and the coefficient of being 138 miles from the nearest shop when the bearing goes.! I am not! Don't worry about them, Drive it like you own it! If you wan to run sand in your bearings, do it.
