jfkmk
Jul 28, 2015Explorer II
Turtle n Peeps wrote:cmcdar wrote:Turtle n Peeps wrote:cmcdar wrote:
It's funny that it seems irritating to some that several folks are fastidious about maintenance and safety.
Why should this bother anyone? It should bother people that there are many out there that are willfully ignorant of even the most basic safety recommendations and regulations.
In other words, if I repack my bearings every year - why should this matter to you?
LOL, if you talking to me I'm not irritated at all. I really don't care if you pack your bearings every night at the campground. I just find it fascinating that when I ask people if they do the same with their TV I get a blank gaze with an open mouth.
The question for you is: You say you pack your trailer bearings every year because it has to do with "fastidious maintenance and safety". Do you repack your TV bearings every year too?
I have asked you, if you do not agree with manufacturer's recommendations, how often do YOU think it should be done? Ever? Never?
...waiting for reply...
Actually you didn't. You're confused. It was Dog you asked, and he answered you.
But since you seem to want to know from me, I will tell you.
As several posters have already said, axel makers have no idea what their axles are going to be put on. Couple that with the fact that you can be sued for making a hair dryer and not having a label on it that states: "DO NOT USE THIS PRODUCT IN THE SHOWER."
I do all my own work. I check my trailer bearings and brakes about every 7 to 10 years. When I say check, I mean just that, check, not pack. I put about 4 to 5K on my trailer/ year.
It goes something like this: It's been 7 years since I have checked my bearings, time to check them. I pop a hub cap off and take the nut off and pull the drum. I look over the brakes and also the bearings. In 28 years I have owned the same trailer I have NEVER seen anything wrong with the bearings. They have OEM bearings in it. In fact, they pretty much look the same as when I packed them. No rust, grease where is should be, the proper amount of grease, seals look good..........good to go.
The brakes on the other hand have wear on them. Not so much the shoes, but the other hardware. Especially the magnets. They are the biggest wear item by far. This is the main reason I pull the drums that often. Because of the wear on the brake hardware.
As far as when should "you" look at your bearings? I have no idea? I don't know how you use your trailer? I suggest if you used your trailer like these guys do, you check them every trip; and ALSO your TV bearings! You should know what your bearing look like if you check them every year. What do they look like when you check them? Or do you do your own work?
Like I said, it's a sealed system. If the seals are in good shape it won't allow contamination in and grease out so the bearings remain in good shape.
Oh, and to people that say they are not the same bearings, load, bla, bla bla. Not true. TV's can have cartridge bearings or packable bearings in them. Trailers can have packable bearings or cartridge bearings in them. (right Dog :B )They are both designed for weight and load for what they are used for. If anybody thinks that a trailer sees more side load think about this: A truck going into a turn at 40 or 50 MPH. Think of the side load at that speed. It's enormous!!! Like I said, it's a red herring anyway. I have yet to see a bearing fail do to side loading and I have seen a bunch. Besides, the fact that they both are designed for load and stress they are put through.
As far as the Lippert schedule: Is this the same company that built these great frames? :B I think I will stay away from this companies recommendation as far as I can! A few people on this forum have junk trailers because of this companies gross incompetence.
cmcdar I now have answered your question but you didn't answer mine: Do you pack or check you wheel bearings on your TV every year? Also, do you do your own work or do you rely on others for that?
Man, when this thread started out, I felt it was borderline trolling, now I'm sure it's full blown trolling.
T&P, I'm really not sure why you're so concerned when people maintain their trailer bearings. If you feel they're wasting their time, what do you care? Does this create a disturbance in the force that somehow effects you?
But, to answer some of your questions from my perspective:
No, I don't pack the bearings in my tv. In fact, I've not had a vehicle with pack able bearings in any of my cars since the 70's. They've all been either FWD or 4WD. I believe most of the vehicles with packable bearings are RWD 2WD. I could be wrong, so don't slam me, just my observation based on the vehicles I've owned. Yes, I do pack the bearings on my trailer every year. I guess that disturbs you, but oh well. Maybe I'll bring my IR with me the next time I travel and really get your head spinning!
You're wrong regarding the lateral forces on bearings on a TANDEM trailer v a car or truck. If you've ever seen a trailer making a tight turn, one tire is scrubbing one way, the other is scrubbing the other way. This, by the way, is one argument for having ST tires on a trailer with tandem axles. The STs don't provide the same traction as a LT tire, allowing it to slide sideways better, putting less strain in the bearings, axles, etc.
Hate to break this to you, but what you're doing is not a proper bearing inspection. Do you even remove the inner bearing? How do you possible inspect the bearing without cleaning it off?
Your posts are inconsistent. In an earlier post you stated you've packed the bearings maybe three times on a 29 yo trailer. Then you say you don't pack them every 7-10 years, you just do is magical inspection. Which is it?
While I agree my annual cleaning, inspection and packing may be a little over the top, it hardly takes any time, is very inexpensive for me to do, and I'm practically guaranteed a trouble free camping season. I'm certainly not harming my trailer by performing this maintenance.
So my question to you is, why do you care how others maintain their campers? The only reason I'd care would be if I was buying a trailer used. All other things equal, I'd go with the one maintained every year over one that gets this magical inspection every 7-10.
Can we start a new thread entitled "why do people who ignore basic maintenance get upset when others don't?"
