ken56 wrote:
We all have gone through the process of figuring out what can my tow vehicle REALLY tow. There are the numbers, and then there is the truth. Its really just a******shoot, with in reason, isn't it?
I have no idea how you figure "truth" or its some how a krap shoot.
RV folks forget these trucks do a lot more than just pull a RV on occasion. Some never pull a RV trailer but may pull a different type of trailer. Flatbed trailers/stock trailers can be loaded for light hitch weights. RV trailers can't.
With a 1/2 ton truck I prefer to use the mfg tow rating as a max. I also prefer to use the truck mfg GAWR and particular RAWR for how much junk in the truck plus hitch load the trailer places on the trucks rear axle/tires.
I just got a new TV. A silverado 1500 4wd crew cab short box with enhanced trailering package,3:42 gears, 3650 rear axle rating, 7200gvw. OK, opinions please. Just how much can it REALLY tow. Specs claim 9200lb trailer. What set up would you be most comfortable with? 5er or towable? What max weight limits? tounge and pin weights?
I don't see a 3650 RAWR in GM specs but it does show a 3950 RAWR for a crew cab truck.
GM online weight calculator shows a 1750 lbs payload for a LTZ 5.3 3.42 7200 GVWR 4x4 crew cab truck.
Also GM doesn't recommend towing a GN/5th wheel trailer with the 1500 crew cab (ck15543) with the 5' 8' short bed. See your owners manual.
**My wife has a '06 1500 crew cab 4x4 (Z71) 5.3 3.73 axle 4L60E auto and GM says the same .
I did a 1-800 to chevy trucks tech team for their reasons why. They said the truck can handle the payload and tow the listed tow rating but GMs concern was the 5' 8" short bed didn't have the proper clearance issues. He added it was a recommendation only. I put a GN hitch plate in the bed. No issues.
You may want to check with a hitch mfg and see if a sliding hitch is even available and get there input on the issue.
