MookieKat
Aug 27, 2013Explorer
Mike Up wrote:MookieKat wrote:WoodGlue wrote:
You're looking at a "Stick & Tin" trailer aka: Aluminum Siding!
WoodGlue
Is that good or bad?
LinkMike Up's Post wrote:
I stay away from lightweight travel trailers now that I have a real tow vehicle. I looked at about 5 different models and even had a deal fall through right before I signed the papers because it's shoddy lightweight build was actually falling apart on the dealers showroom! I didn't realize how bad it was until we did a walk through with everything operating. Lightweights use "GLUED" or "VACUUMED" Styrofoam around cold/hot conducting aluminum frames, onto thin substrates as luan or other eco 1/16" thin boards. That in turn is glued (or vacuumed) again to decorative board on the inside and the thin fiberglass/gelcoat sheet on the outside. Laminated sandwiched walls. NO THANK YOU.
Since I've been paying more attention to these types of campers, I've seen 2 out of 3 with delamination (wall came unglued).
Plus the aluminum framing is conductive to allow condensation on the walls on certain models. PLUS some models use the aluminum framing around the borders and only have a few internal braces for windows with no normal studs. Then you have aluminum welds which are known to be weak. Ladder makers use rivets for strength as a feature over aluminum welding.
Plus these lightweights have lighter material inside as well. Walls flex around more, cabinetry is lighter and weaker, and believe it or not, even the floors and/or roofs are laminated on some models including "JAYCO". NO WAY!
I recommend the tried and true Aluminum sided stick and tin. In fact many are made with the same studs and wall framing as large mobile homes. I have family with them and they have lasted decades if maintained. If you want a camper to last, these are the ones.
Before I read this post, I had no idea what could go wrong with the light trailers. Now, I am paranoid about lightweight TTs. I feel like now I have to buy a heavy TT and buy a beast to haul it around to the tune of money down the drain on gas!
How many on this forum have had issues with delaminating or seams coming unglued in their lightweight TTs?
44,056 PostsLatest Activity: May 04, 2014
