Mike_Up
Aug 28, 2013Explorer
jerem0621 wrote:
When stick and tin has to be repaired they remove some siding and do the wood repair. When they have to repair laminate they have to replace entire wall sections.
Walk into any campground, USA and look at the laminated trailers. Especially the ones who are 5 plus years old. It's not uncommon for these trailers to have what looks like big blisters on the front of the trailers, many times on the back and around the windows. This is delamination. It could be water intrusion, it could simply be that the fiberglass has let go of the substrait.
IMHO this is a major reason why we see one piece fiberglass caps now. Fiberglass caps hold up very well aesthetically speaking.
For me, I prefer sticks and tin. But really if you have wall damage from a leak its a bad situation with either build method. Sticks and tin is easier for an experienced DIYer to repair at home. I have never read about an effective home brewed solution to delamination.
Thanks!
Jeremiah
That's what I'm talking about. 2 out of 3 campers I see some sort of bubbling or waviness in the fiberglass. One guy who recently sold his, had it sitting out near the street where it was easy to see. Some days it looked perfect, other days, you could see the one side with a huge bubble down most of the side. The weather can hide or show the delamination, but it's there. I have even seen it on a few brand new campers sitting on the dealers lot.
Some campers have small delamination bubbles of 7" or 8" and others have areas in the feet. I honestly see it so much, I would rather downsize the camper to fit my tow vehicle than get a lighter laminated camper of a bigger size. Even some hybrid campers are going back to stick and tin construction although there's not many unfortunately.
44,056 PostsLatest Activity: May 04, 2014
