TxTiger
Aug 29, 2013Explorer
Proteus wrote:
I won't even consider a "stick and tin" trailer for the following reasons.
1) it's cheap crap, pushed because it uses residential construction techniques and requires minimal worker training, and no special factory machinery. 1950s era tech.,,
2) wood gets wet, and rots. Insulation "batts" retain water, and shift.
3) it creates trailers that are far heavier than they need to be, and require large trucks to pull. A truck is a horrible daily driver. They handle like crap, with lousy gas mileage. Why buy one just to pull a trailer? Why not buy a trailer at can be pulled with a normal vehicle?
1) Residential construction methods are proven and go back much further than the 1950's. I've not seen any laminated/bonded luan/Azdel constructed single/multi-family residenses in my area.
2) Wood does rot if it stays wet. Catch the leak in time and you're ok. Even minor leaks in fiberglass sided trailers can turn them into a money pit to repair if they delam.
3) I own several trucks. Some like my half ton Silverado is a great daily driver and very comfy on trips. It gets over 20 mpg on the road. Not sure what a "normal" vehicle is. A Ford Focus?
44,056 PostsLatest Activity: May 04, 2014
