- ShinerBockExplorerYes, overheating was common with the LLY due the intake and cooling system design. There were even a few lawsuits over it.If it didn't happen to you then consider yourself one of the lucky ones or you did not really tow much weight.
There is a reason why GM(and the others) started increasing the size of their grilles and designed intakes to pull cooler air with less restriction. . This is also the reason why the LBZ had a larger less restrictive intake pipe with less sharper bends.
Duramax LLY Overheating Solutions
Duramax LLY Overheating: The GM Solution and Beyond
COMMON PROBLEMS WITH THE 6.6L DURAMAX DIESEL larry barnhart wrote:
donn0128 wrote:
FishOnOne wrote:
falconbrother wrote:
What's your, knowledge, thoughts, experience, on the GM Duramax diesel?
It's good but I would stay away from the LMM due to lacking def on the emissions side.
As for the LP5 it's a completely new design that has had some bumps along the way.
The LLY was infamous for overheating. It was GMs first attempt to up HP from the LB7 and was a disaster when towing heavy.
I guess our LLY must be special because it has never over heated on any climb and I like the 5 speed. I use the scanguage II. chevman
My parents previous truck 05 Duramax never overheated either. I know they pulled some pretty good hills in the smokey mountains with it.- DutchmenSportExplorerI don't care about numbers, statistics, anyone's idea, any scholarly critiques, or manufacturers hype.... all I know is, I love mine and it's had absolutely zero issues since I purchased it new. It tows like a beast. I absolutely love this truck. Its a 3500 Dually long bed crew cab Duramax Diesel. Did I mention, I absolutely love this truck!
- larry_barnhartExplorer
I guess our LLY must be special because it has never over heated on any climb and I like the 5 speed. I use the scanguage II. chevman - Me_AgainExplorer III
But it’s an easy fix and if someone is shopping for an old truck, a good condition lily, needing a little retrofit work is as solid as any of the era and better than a 6.0 Powersmoke.
But you still have a 5 speed tranny. - Grit_dogNavigator II
But it’s an easy fix and if someone is shopping for an old truck, a good condition lily, needing a little retrofit work is as solid as any of the era and better than a 6.0 Powersmoke. - Cummins12V98Explorer III
Grit dog wrote:
Well, the Dmax is the ONLY diesel out of the big 3 that hasn’t changed displacement or been scrapped for an all new engine. That says a bunch. Apples to apples, the Dmax gives up nothing to any of the others, year by year, save for the Cummins being simpler for some repairs and the Cummins still being very arguably the longest lasting internals.
The Cummins 6.7 is not ALL NEW.
Quote from Allpar.com "Nearly 40% of the new engine’s parts were carryovers." - kerrlakeRooExplorer
Lantley wrote:
kerrlakeRoo wrote:
Another generator thread,,,,,, ooooops sorry same arguments different toys.
Not quite this is Honda guys debating with Honda guys.
The other guys, Champion(Ford) and Harbor Freight(Dodge/Ram/Fiat) pick a name will have to start their own thread
Welllllll
I was taught to never trust anyone in a bowtie. :R
And yes, I'm making fun of the other thread, in this thread.
But, I'll be polite and stop now :B - LantleyNomad
The other guys, Champion(Ford) and Harbor Freight(Dodge/Ram/Fiat) pick a name will have to start their own thread - kerrlakeRooExplorerAnother generator thread,,,,,, ooooops sorry same arguments different toys.
44,046 PostsLatest Activity: Aug 02, 2025
