I'll pass along some of what I found out from Dexter.  A good company I might add, where the customer is still part of their business.
In talking with their tech service I asked the question on why put the EZ lube feature on a TT or a 5er?  The answer I got was interesting.  They know one of the leading causes of axle death is lack of lube of the bearings.  They went on that the average person never even looks at the running gear, less grease them on any type of frequency.  By bringing the EZ lube into trailers other then the boats they were made for, gave the axle a better chance the owner may actually give the bearing some lube giving it a chance to survive.   A point I never considered that the issue was this bad. So there is part of the reason EZ lube shows up on TT's.
Now what do I do?  I do all my own service.   Including installing and aligning my new axles to meet and be well inside dexters spec here in my own yard. Proper axle alignment on a TT is a whole other topic.  I use quality name brand grease and I hand pack so "I" know what I have.  Even though I bought my new axle tubes with the Ultra lube (alko's version of EZ lube) prep but I do not use it.  I have it in case on a very long trip out west 5,000 miles from home I need to add grease from bad dusty conditions etc. I have yet to use it.
Since I have done the re-pack I have no issues going beyond a year. Even 3 years but that would be it. Don't trust the brake any more then that. The grease from my hand pack still has good grease on both sides of the bearing after 3 years. It's not hard, it is quality grease.  BUT, I know what I have. There are no short cuts taken and I use quality double lip seals when ever the wheel comes off. If I had to hire this out, I would not trust it like this.
And yes, I too bring parts and grease in the camper to do an axle job on the side of the road. Hope I never need to use it.
I upgraded to self adjusting brakes when I put the new axles in. So they are always up in adjustment. Between the self adjusters and the #10 gage star pattern wiring upgrade right to each wheel, I have as good as I feel I can get on a brake drum setup.
Observation is key.  When on long trip, every time the truck stops for gas, the camper gets a walk around.  Hubs felt for temp, look for wicking grease, look at the tires, look at the hitch.  Amazing what you can find just looking. Stuff happens. But doing the simple looking can go a long way to catching issue before big problem come.
The once a year recommendation from the manufactures, they have to give something that is reasonable and fits what the open public can handle. Remember one of the causes of axle death? lack of lube. Not that it fly's out, that it doesn't get done.  If a manufacture was to give 3 years, they may never get grease...
I will say a brand new axle wants and needs a look and repack no more than the 1st year. No way would I trust the modern day axle lube job from the factory.  All 6 of the trailers I bought, cargo and TT all had bare minimum grease in the bearings. When I bought the 6 x 12 cargo trailer, the dealer even said, don't go too long on your 1st   greasing. I was shocked it was so light. Then I got use to it not coming when new.
Axle greasing is an individual thing. Do what you feel is right for you and you can trust.
PS. This is the wheel off my camper I bought used, hand packed bearings.  I bought this camper from a state that does annual required inspections.  Odds are high when they pull the wheel for brake inspection, pull it look and put in back on. No new seal.  Well that nicked the seal and you get this.  Again I trust no ones work other then my own or someone I have taught or who taught me.
