2-MTnesters wrote:
...There have been many complaints that wheal seals have blown out using the EZ Lube system. Also rally no need to fill the entire hub with grease which is what ultimately happens. Tim
in 2012 I bought a used cargo trailer. The only maintenance the previous owner ever did was pump more grease in every year. The seals eventually blew out because the hubs were completely packed full of grease.
My game plan was repack the bearings, inspect brakes, etc before I started using the trailer, but I sure didn't anticiapted a complete rebuild of every wheel hub. The owner claimed that the brakes worked very well and would stop the truck. That was an exaggeration - when I got out on the road when I left his driveway, I had to crank the integrated brake controller up to the highest setting to get any braking action at all, and it was minimal at that. That made it obvious something wasn't right with the brakes.
If you have EZ-Lube hubs, they don't eliminate the need to do a full repack every so often.
Here's what I found when I got started on the project:
All 4 rear grease seals were blown, which explained why the brakes didn't work very well. The brakes were covered in grease.
The project required all new brakes and drum/hubs at all 4 wheel positions.
The trailer was 4 years old when I bought it, but had a LOT of miles on it.
