the_bear_II
Jun 27, 2013Explorer
The clunking noise may have been from your magnet hitting the drum dependin on how hard you shook the tires/wheels. Did you feel the wheel wobble on the axle ? If so that would indicate the need for some sort of bearing work. For awhile a lot of new TT were coming from the factory with loose drums. For some reason the axles were being delivered without the drums being properly tightened onto the axle. I remember reading many posts where several rv'ers had discovered the drums weren't tight and bearing were ruined.
44,067 PostsLatest Activity: Jun 05, 2026
