LaunchnRetrieve
Jun 28, 2013Explorer
SJones37 wrote:
For the 10 minutes it would take, ide put a jack under the axle and get the tire off the ground.Then you could put a bar under the tire and rock it and see if its a bearing .Check lug nuts,might have a couple loose ones.For the little time it will take to check all wheels its worth the piece of mind.Before i spent 350 on a shop ide do some looking first.its pretty easy to pull bearings,clean and repack.Its a little messy but not to hard.
I've got the weekend to play with this and will try the few things you've suggested. My appointment for work is two weeks away so I have time to play with this to the limits of my mechanical abilities and resources.
44,067 PostsLatest Activity: Jun 05, 2026
