N7SJN
Apr 12, 2016Explorer
Wheel bearings
After 12 years and 10's of thousands of miles a tire tech advised me that I should have my brakes and wheel bearings checked. Bottom line breaks were still good and the wheel bearings also. I do not...
proxim2020 wrote:Aqua-Andy wrote:
Actually they do. If you disassembled that failed wheel bearing from your Avalanche you would find of all things, two tapered bearings filled with grease. The trick is they use quality parts and not Chinese ****. GM uses Timken bearings as OE. So replace your bearings with a quality product and use good grease, you should be good for years. Other posts claim there is a difference weather on a truck or trailer, there really is not.
The bearings are supplied with a lifetime of grease and are permanently sealed.
