azdryheat wrote:
I've got three axles and I've yet to do anything to the bearings or brakes in 2 years of owning it. I'm not worried about it. When was the last time you checked the bearings on your truck? Are the trailers any different?
There are some differences. A lot of your 2wd trucks come with a non-serviceable sealed front hub bearings. There is no maintenance required for these. You simply listen for any grumbling or excess play and if any is detected then you replace it. Axle bearings are typically lubricated via a gear oil bath from the differential. The fresh oil bath greatly extends the life of bearings sometimes extending the service life to the life of the vehicle. The bearing systems in vehicles these days are designed for longevity.
A little bit of preventative maintenance doesn't hurt. Even though I know my axle bearings should be fine, I still pull my axle shafts every couple of years to inspect the seal and bearing for wear. It's cheaper to catch a problem before it turns into a real problem. When you turn a blind eye to things, sometimes you get bit, sometimes you don't. A story of someone successfully turning a blind eye shouldn't be used as par for the course though.
