Bluedog
Aug 13, 2022Explorer
Wheel Bearings
I have a 28 ft. TT and had the wheels bearings completely serviced in 2019. I have used the trailer only twice since then for 2 trips of 400 miles total. I would like to make another trip of about eq...
klutchdust wrote:
"Used to be, likely still applies, not a good idea to mix different types/brands of grease. "
I would really like to see some proof or research/testing done by a reliable source to back up that statement. Having serviced hundreds of semi trailer units and not knowing what grease was used previously, it was a rarity, rarity that a bearing in our fleet of over 10k units ever had a bearing failure. A bearing was only serviced when the unit was brought into the shop for a brake change. That could be anywhere from 1 year or 5 years. Servicing wheel bearings every year is just nonsense. I call malarky on that one.
Mike134 wrote:
inner bearing about the same the outer bearing on the Cutlas is smaller. Weight per wheel about equal 1200lbs 455CI weighing them down (smiles)
By chance you're not one of those that does an oil change every 3000 miles are you?
