Bluedog
Aug 13, 2022Explorer
Wheel Bearings
I have a 28 ft. TT and had the wheels bearings completely serviced in 2019. I have used the trailer only twice since then for 2 trips of 400 miles total. I would like to make another trip of about eq...
BarneyS wrote:Really it is about the same. On our class 8 trucks and trailers we would check and service bearings at about 100K miles. True the bearings are bigger but so is the load. I'm not a rookie mechanic as you can tell from my profile and I do believe some folks take the bearing service a little to far.Bird Freak wrote:
I don't get all the concern about repacking bearings. OP has 800 miles since serviced. How often do any of you repack the front bearings on your car or truck?
Its the same bearing set up.
Not the same ball game! The front bearings on a car or truck do not see any of the huge side loadings that double axle trailers put on their bearings when they turn or back into a campsite. If the trailer wheels turned like a cars, then the side loadings would not be there and the recommended service interval would likely be much longer than it is now.
