Steve_911's avatar
Steve_911
Wheel chock question
When setting up a single axle tt where the site is not exactly level, what is the best way to chock a wheel that is elevated on a Lego or other type of block under the downhill wheel? A newbe question.
Thanks in advance for any advice.
  • RDMueller wrote:
    Many different ways to do this. One option is to use Andersen levelers. Because of the design, the wheel is basically in a cradle once the 2nd piece is put in place. No way for the wheel to roll either direction. Essentially levelers and chocks all in one.
    Been using a homemade version of these for 3 years, now. Wouldn't travel without them.
  • SoundGuy wrote:
    Can't beat a BAL Single Tire Locking Chock ... fully adjustable so it won't ever slip out of position as can plastic chocks. This pic shows mine used on a single axle popup but it works just as well with any single axle trailer. :)
    Safest solution for a single axle trailer.
  • ^ That is a really neat device!! Simple and performs 2 jobs at once! I have never seen it before but now I am very tempted to try!
  • Many different ways to do this. One option is to use Andersen levelers. Because of the design, the wheel is basically in a cradle once the 2nd piece is put in place. No way for the wheel to roll either direction. Essentially levelers and chocks all in one.
  • eHoefler wrote:
    They chocks that will lock into the Lynx leveling blocks
    Lynx Stop-n-Chock ... problem is, depending on tire size they often don't snug tightly against the tire and thereby still allow the trailer to rotate on the axle. Lousy solution IMO.
  • They chocks that will lock into the Lynx leveling blocks
  • You have to have enough legos to build a platform in front and in back of the tire so you can put the chocks in.
  • This is why I use 2X12's about 3 feet long. Plenty of room to chock the tire.
