RCMAN46
Aug 14, 2014Explorer
mister_d wrote:
Hot a guy out to get the bolts free and I replaced the spring(: The original wasn't cracked .. just missing the pin down the middle. Now my concern is that the bolts are tight enough. Lippert sent nuts and washers instead of lock nuts for the u-bolts.
Once the bolts are properly tightened get another set of nuts and double nut the u bolts.
Use the torque values that you get from Lippert. U bolts typically are not very hard so be careful not to over tighten or you may strip the bolt.
44,052 PostsLatest Activity: Oct 29, 2025
