hornet28 wrote:
Your not long until your nearing the 60 ft mark. I'm just over 50 ft with the 5th wheel but 60 ft with my bumper pull car
Very true. I'm just shy of 57' end to end with our bumper-pull. A FW of the same size would likely cut that total length by a good 5'.
That said, once you are in that range, I'm not sure a 10% variance one way or another makes the difference, and the number of people pulling with shortbeds seems to indicate that it's not a world of difference. I think it likely becomes more an issue of priorities. The long bed will give you room for gear and/or a gear box in your bed, and removes the need for a slider. A short bed is a bit easier as a daily driver and will fit into a smaller garage if need be.
