Huntindog
Dec 05, 2020Explorer
IdaD wrote:As a blanket statement, this can be false.
Just my two cents but having one of the big diesels hanging over the front axle goes a long way to eliminating the need for weight distribution. Will 1400 lbs reduce the the front axle weight on that truck? Sure. Enough to matter...eh, not so sure. Even loaded up you still have more weight on the front axle than an empty gas version of the same truck does.
I'd at least try it out before you go spend money.
The trucks may not always be the "same"
The front suspension can have different spring rates and shocks. So it may be set up for the heavier diesel engine. Removing weight from the front of a vehicle with heavy duty front suspension would not be desireable.
