Vanished
5 years agoExplorer
When is weight distribution needed?
I'm not trying to stir the pot (well, ok - maybe a little) but my question is serious... In the old days the hitches/trucks required WD and Sway control for over 5k lbs... then we went to 2.5" hitches... Now my current truck has a 3" hitch...
Here is my setup:
2019 F350 Dually Crew Cab Diesel 4x4
2021 Grand Design Momentum 28G travel trailer toy hauler
Specs show my truck can HAUL (w/o weight distribution) 2100lbs on the hitch, trailer shows about 1400 lb tongue weight - maybe less when it's loaded (Toy Hauler)... 12k GVWR and 32' long...
Truck has built in sway control...
So my thoughts are to drop it on the ball and try it... Am I nuts?
I have no issue getting a WD/SC hitch setup but it seems like an overkill in my situation... And they don't even make a 3" setup that I've found - only 2" or 2.5" and both would need sleeves/adapters to fit my hitch - which I was always told to not use an adapter with a WD hitch...
Thoughts?
Here is my setup:
Thoughts?
