ShinerBock wrote:
FishOnOne wrote:
I agree in general with the compression ratio but add a turbo and you add another variable with compression. The Duramax has actually at one time (LBZ) reduced compression, but improved performance and fuel economy over the previous gen which started out at 17.5
Even with a turbo, compression ratio still plays a factor in getting more energy out a drop a fuel. However, as with the other examples I have given, this is not the only reason for better fuel economy. GM was able to improve fuel economy and power through more aggressive tuning which backs up my previous statements.
Also, if you read what I stated earlier again I said "Interestingly, this compression ratio spread matched up perfectly with PUTC's last diesel truck comparison." meaning that I found it interesting that compression ratio spread matched up perfectly to the PUTC test. You can disagree with me or not, but I will still find it interesting.
The real world fuel economy on Fuelly.com shows a different story though. There the average fuel economy for 2014-2017 3/4 tons shows GM at 14.6 mpg and the Ford at 14.2 mpg. However, Cummins is still ahead of the both of them with an average of 15.7 mpg. Regardless I still find the compression ratio and PUTC test fuel economy spreads being very close..... interesting.
I agree and understand your point. I guess I was pointing out in previous tests there has been no real coorilation to compression ratio with these particular trucks since there are so many variables at play. And I do find this stuff interesting as well.
