CavemanCharlie
Dec 23, 2013Explorer III
oldokie wrote:CavemanCharlie wrote:
I wonder why they need separate wire connections for sat and cable? My sat dish is fed into my house using a standard co-ax cable.
you can't use the sat. receiver on the cable that goes thru the ant. booster since it sends voltage to the dish thru the cable.
OK, I see, and they put the cable wire in the same line as the antenna wire and put the sat wire in a different one. Makes since I guess. But, why can't you put the cable wire into the sat wire since you need no booster on cable. Then you would still only need one hookup on the outside of the camper.
44,056 PostsLatest Activity: May 04, 2014
