HadEnough's avatar
HadEnough
Where do you get service done?
It's been a nightmare getting service done on my Ram 2500/Arctic Fox.
A while back someone broke the transmission/clutch when putting a new clutch in. Now I have to double clutch it when cold to shift. Barely shifts at all.
No one will put in a rear window. I have the window but they refuse to touch it.
I just drove all over town to several tire shops and no one will put tir s on my truck, align them and balance them. I asked to get the alignment done with the TC on, but showed up with it off to make mounting and balancing easy. One place didn't want to ordery load range H tires, the other didn't want to do the alignment with TC. My perfectly good tires are destroyed on the edges because the alignment was done without the load last time.
Can't find anyone to look at the transmission/clutch mess the other shop made. Only option I'm hearing is dump the transmission and buy a new one.
And I need an oil change. I wonder if anyone will want to do that.
So the question is... Where do you get your vehicles serviced?
I don't understand why no one can do these simple things.
  • I leave my camper on and the Chevy dealers in Parker, AZ and Crivitz, WI and the NAPA dealer in Salome, AZ all do oil changes and lube with my camper on. The Ford dealer in Crivitz, WI does wheel alignment with the camper on.
    Keep calling around,
    LeRoy
