- CavemanCharlieExplorer IIINothing special about that antenna. A decent automotive parts store should be able to find it for you. A truck part / repair store might be able to help you also.
- Fire_InstructorExplorerLooks like the exact same one that I had on my old Rockwood, so I'm thinking that they may b universal.
- chracatoaExplorerThanks, I'll try some of these ideas.
- CamorhinoExplorerStandard automotive universal fit antenna. Radio Shack or just about any auto parts store will have one. Easier to drill all the way thru and put a bolt and nut in and be done.
- D_E_BishopExplorerI think that a larger diameter screw or drill all the way through and use a longer screw and a nylon lock nut to tighten. put some Loctite on the nut and around the head and you'll be pretty watertite.
Then again, if you really want another antenna, I'd send you one but the screw hole is the clearance hole and the threads were in the other half of the ball and that was part of the base. PM me if you want it. - _1nobbyExplorer
chracatoa wrote:
So the screw thread wore off in my Jayco's antenna. Unfortunately I think I have to buy that whole piece to fix it. Any ideas where I can find it?
If it was me...I would try re-threading next size bigger and get a new bolt / screw.
At this point, you have nothing to lose. - LynnmorExplorer IIEbay
