ScottG
Dec 30, 2014Nomad
FishOnOne wrote:
Beware of some after market rebuilders... I would suggest taking a hard look at a MOPAR/cummins rebuilt crate engine as most specifications are rebuilt to original new specifications.
I know it's a long shot but I've heard bad injector/s can cause a really bad knocking noise and can be misleading that the engine itself has a problem.
Also when selecting a remanufactured engine you should consider the warranty also.
Good luck...
Yes, bad injectors, a loose injector line clamp, broken manifold.
Could be a number of things that aren't nearly as expensive as an engine.
