carlw32
Dec 31, 2014Explorer
FishOnOne wrote:carlw32 wrote:
Don't know what caused it yet they have not torn into the engine however at this point I don't care. Just want it fixed if it was paid off I would look for another truck so I just have to fix it probably going to have to look for an engine where they don't require a core as my block is toast along with the crank I am sure a rod came out of the block so it's just a paperweight.
Carl,
I notice you run a H&S mini max... Any possibility this could have caused your engine failure?
I keep that on stock use it to monitor EGT's is all and read engine codes. Only tried the other settings when I got it and have not used since. I always keep it on stock because I know that the clutch can't take it and I don't have the injectors and fueling for the higher settings.
