Cummins12V98
Jan 01, 2015Explorer III
Hannibal wrote:Cummins12V98 wrote:Hannibal wrote:
Are you suggesting the Cummins isn't suitable for rv towing? Do Cummins owners need to rent a reliable car for transportation around town while their Cummins Ram sits in the campground because it can't be driven normally without developing problems from fuel dilution? I would not own a truck with such ludicrous restrictions.
If you are talking to me, did you read what I said?
"I agree it is a problem but if a person uses the 07.5 thru 12 6.7 like a truck instead of a grocery getter the fuel dilution will not be problem".
Yes.
Reason I asked is you asked you said "Cummins isn't suitable for rv towing?" I said it was not a problem if used as a truck.
I stand by what I said not sure how you came up with your comments.
If all you do is short trips NO DIESEL will fare well in those conditions.
I local drive my 11 HO Dually all the time long and short trips plus tow with it. never had a forced region occur and fuel dilution less than .05%
What I said originally.
"All that was talked about was fuel dilution being a problem. I agree it is a problem but if a person uses the 07.5 thru 12 6.7 like a truck instead of a grocery getter the fuel dilution will not be problem."
