westend wrote:
HaulinBass02 wrote:
The gens, are 20" long by 13" wide and I have to orient them to be able to reach the control panel which means they have to be placed length wise front to back so I can place them side by side on the tongue. Other than a rear rack, the front tongue rack actually seems to be the best bet. I don't relish the thought of getting them in and out of the back of the sub any time I want to use them. I have secure storage at my house so theft at home isn't a big deal so I am fairly sure one of the over the tongue racks or a custom variation thereof is how I'm going to do this with the gennys bolted and locked down to them.
Before you bolt them down, I'd suggest to test run them in that location. You may find that the noise or vibration is something that you can't endure, inside the trailer. I've found that running a generator bolted to the trailer is way too much noise.
This is a good idea and I've thought of that. The gens already have rubber feet on them and I have some fairly soft rubber pad that I was going to insulate them with. I might also use some thin rubber on the mounting points to insulate/isolate from the trailer frame. But we will see how this all works out.
