jaycocreek wrote:
You clearly don't care about your safety over bringing your toys.
I see people hauling one or two snow machines and or ATV's pulling a trailer almost everyday and I have never seen a broken axle/blow out or wreck caused by being a tad over manufacturers weights...
Heck, just go to the fiver forum or truck campers and you will see over the payload all the time or here my axles say it's okay to be over payload.
All the guy wants to do is haul one ATV in his truck and pull his camper..... I wouldn't hesitate to do it with his rig and I have been hauling an ATV in my truck pulling a trailer since I got my first ATV in 1988 with 3/4 ton truck with a GVWR of 7200 lbs.
Never an issue.
Just because you see folks "doing" it doesn't make it right nor is it safe to do (and I am not talking about broken axles)..
There is more to it than axles which may be exceeded, tires, rims, lug nuts, springs, shocks, brakes and even stability..
Although the OP has a 2009 a quick check of Jayco on the same model number but a 2014 model indicates the OP will be over the cargo weight without ever placing anything inside the trailer.
Per Jayco
HEREWeights
Unloaded Vehicle Weight (lbs) 4,125
Dry Hitch Weight (lbs) 510
Gross Vehicle Weight Rating (lbs) 6,500
Cargo Carrying Capacity (lbs) 2,375So from the start with the advertised empty tongue weight the OP is already 110 lbs over the allowable cargo weight of the vehicle..
Trailer has gross weight rating of 6,500 lbs and that means the tongue weight at 10% can be 650 lbs and at 15% 975 lbs.
Loaded the OP will have 250 lbs to 575 lbs OVER the cargo weight.
Then add in that this trailer is 28ft in length and I think the OP is going to quickly regret trying to drag all that weight around with his current truck.
That additional 800 lbs of ATV sitting 4ft to 6 ft in the air is going to make the whole rig really unstable..
The OP IS overweight and IS a dangerous setup with that ATV on the truck.
Sorry if the truth hurts but someone needs to step up and call out a bad situation before the OP gets hurt or breaks down..
