mich800 wrote:
Cummins12V98 wrote:
Bionic Man wrote:
I’m sure at some point you reach dimensioning returns. But it isn’t going from 6 to 8 gears.
Did you see the Ike run GM 10 speed against RAM 6 speed? Sure didn’t shine from what I saw.
The problem is you are basing your analysis on one specific test. In the real world vehicles must perform in a much broader range of scenarios. Just like the phrase you don’t race on a dyno holds true here. Every trip or hill you drive is not pedal to the floor and see how it goes.
Well said... The 10 speed will have more options to select the right gear for the engines power band over various load and terrain situations.
Having said that one could say the 10 speed allowed the Duramax with less torque than the Cummins to equal it's performance up the Ike.
