Cummins12V98 wrote:
FishOnOne wrote:
mich800 wrote:
Cummins12V98 wrote:
Bionic Man wrote:
I’m sure at some point you reach dimensioning returns. But it isn’t going from 6 to 8 gears.
Did you see the Ike run GM 10 speed against RAM 6 speed? Sure didn’t shine from what I saw.
The problem is you are basing your analysis on one specific test. In the real world vehicles must perform in a much broader range of scenarios. Just like the phrase you don’t race on a dyno holds true here. Every trip or hill you drive is not pedal to the floor and see how it goes.
Well said... The 10 speed will have more options to select the right gear for the engines power band over various load and terrain situations.
Having said that one could say the 10 speed allowed the Duramax with less torque than the Cummins to equal it's performance up the Ike.
UH why not state FACTS here. RAM 6 tires and heavier.
My analysis is based on my personal experience. Also some of what I have seem.
The GM should have smoked the RAM plain and simple.
And if it had you would have Ditched that the Ram had more tires and was heavier so it was predetermined that the Dmax was first up the hill, which it was anyway, even if it was by a couple seconds. They will weigh them down and see what happens.
