Cummins12V98 wrote:
Huntindog wrote:
Cummins12V98 wrote:
Grit dog wrote:
Uhhh, who gives a schitt.
I just watched my first Ike towing video ever. Kinda under whelming. Guys wouldn't stfu....anyway, both trucks were identical up the hill straight across tie I think.
Makes sense, litle bigger truck, 10% more tq, little smaller truck little less tq. And they both hammered up the hill at the same speed.
What did I miss?
Worst part of it is I want to live THERE again!
Well with all this hype about the 10 speed trans I would have thought the GM would have performed MUCH better.
You still don't get it.
Under the test parameters....
Both trucks were pretty much able to achieve a "perfect" score (time). How can either truck do MUCH better?
I do get it, the 30-60 time to get to speed should have been quicker and there were other places that they did not maintain 60.
Waiting on the BIG pull. GM can use the 3.42's for an excuse. Ford and RAM will have 4.10's. They all are SAE rated to pull 35k.
If RAM does not get it's AZZ handed to it what will be said then???
On this test, the Chevy was a 3/4 ton and like 18,000 Max towing. I can't wait until they line up duellies from all three and drop 35k and see what happens. Hopefully using a tall fifth wheel as I find wind resistance more important than weight on drag up a mountain at 60.
