carringb
Jun 22, 2019Explorer
With the update about the hot water heater, this sounds like the likely culprit. When you winterize, do you isolate the water heater? If not, you're supposed to remove the anode rod, because antifreeze attacks it, and this will result in a metallic brown sludge that takes a while to clear up.
44,071 PostsLatest Activity: Aug 30, 2026
