swhunter
Jul 10, 2019Explorer
Which 19.5" tire to choose
I posted for the first time on here clear back in November of 2018. I was asking about upgrading to 19.5” wheels and tires for a 2000 Ford F350 SRW. I got a lot of good info from others here. I heard from some people about how hard it is to get wheels from Rickson. Well it seems that is the same case for me. All the correspondence I have had with Heather (she does the sales orders for Rickson) has been positive. But I never heard from the owner of the company or other personnel as far as getting my order for the wheels filled. I really wanted to buy wheels made here in the USA, but it didn’t seem like that was going to happen. So I ordered a set of Vision 19.5” wheels through a local Discount Tire store. The wheels came in within one week.
When my camper is fully loaded, I have 7850 lbs on the rear axle, or 3925 lbs per wheel. I am now researching tires through the Rickson website and also looking at tire manufacture websites. It looks like I could go with 245/70R-19.5” tires with load range H, rated at 4940 lbs, and a 33” diameter. These would give me a safety margin of around 1015 lbs. Or I could go with the 265/70R-19.5” tires with load range G, rated over 5000 lbs, and a 34” diameter. These would give me a safety margin of around 1100 lbs. I like the weight capacity and height gain of the 265s, but I am not sure if that is overkill. I also don’t want to cause other problems later on because of going with that big of a tire.
I don’t want a steer tire tread or straight highway tread tire. I need a good all-terrain tread that will be good when the ground is wet, whether in the mountains or the desert.
Heather did recommend the 265/R-19.5” Toyo M608 load range H, 16ply rated at 4940 lbs.
Anyone running 19.5” wheels on a SRW pickup, what tires do you prefer?
Thanks in advance for any information you can share.
swhunter
swhunter
