wny_pat1
Aug 16, 2021Explorer II
No, they are not waterproof!!! They are water resistant to a point. They have to be mounted vertically on a non-flammable surface, with the power terminals facing downwards. I'm mounting mine in a "ventlated" box. Something to keep direct water spray from saturated the unit. They are rated to IP43 protection When installed with the screw terminals oriented downwards. IP43 is Protected from water spray less than 60 degrees from vertical. I am installing mine in a waterproof junction box rated at IP65 - Protected from low pressure water jets from any direction. Found it at www.amazon.com/dp/B07PDV2F2N?psc=1&ref=ppx_yo2_dt_b_product_details.
I have a Scamp 19, similar to a small fifth wheel. I am mounting mine on the front outside fiberglass wall. I would like to mount mine upside down on the loft over the pick up bed and am awaiting comments from their dealer. Your charger should be mounted as close to the trailer batteries as possible.
