Skibane
Aug 16, 2021Explorer II
1. Are you sure that your DC power converter doesn't deliver 14+ volts while it's recharging the battery?
Nowadays, most converters are at least "2 Stage", with a higher initial charge voltage until the converter determines that the battery is charged.
2. Most solar panels will deliver well in excess of 17 volts. All you need is a solar panel charge controller that can be adjusted to the higher charging voltage your Lithium battery requires.
