- TimfmCTExplorer
retiredcamper2011 wrote:
After some research I chose the ADCO cover and used it last year for the first time and now I have winterized my trailer and just put the cover on it again 2 weeks ago. So far, so good. It looks nice, has zippers to access trailer if needed and many straps that go underneath as well as tightening straps at both the front and back end. If folded correctly for use, just lay in place on top of trailer and unfold over front, sides and back. My wife assists with a ladder while I am on the roof. Maybe 20 minutes. I would recommend it.
Hi,
We have a 5th wheel 2012 Cedar Creek 29RE. We would like to cover it for Florida summer weather. Our site is in a community that has year round residents. In consideration of the residents are there any covers that fit "snuggly" that follow the contours of the RV? I've seen covers that really are not very attractive. - BarneySNomadFor the first time in many years our trailer will sit outside in the Michigan winter instead of making the trip down to Florida. I researched the Calmark cover but the cost was just too high for me to justify(around $950) so purchased an Adco and installed it yesterday.
I used air conditioning insulation tubes cut to fit for covering all possible areas of wear so am hoping it will survive for a few years. We do not cover it at all during the summer.
Barney
- retiredcamper20ExplorerAfter some research I chose the ADCO cover and used it last year for the first time and now I have winterized my trailer and just put the cover on it again 2 weeks ago. So far, so good. It looks nice, has zippers to access trailer if needed and many straps that go underneath as well as tightening straps at both the front and back end. If folded correctly for use, just lay in place on top of trailer and unfold over front, sides and back. My wife assists with a ladder while I am on the roof. Maybe 20 minutes. I would recommend it.
- ReedgaExplorerI have had ADCO cover now, for 2 years.
We had a tear in the cover from a sharp area on the trailer.
ADCO sent a repair kit FOC.
They have very good follow up service.
When you call them you speak to a real human.
From my experience after the first year,when you cover your RV you have to take every precaution to insulate the cover from sharp or small protruding areas.
I use foam pipe insulation the full length of my rear ladder.
Where the ladder rungs protrude out from the ladder frame this is where I encountered wear a small tear at each step of the ladder. I use pipe insulation that accommodates 1 inch copper pipe. Fits nicely over the ladder.I hold it in place with a few zip ties. Also use this pipe insulation on the top side of the ladder where it goes over the roof.
ADCO includes small bags to fit over you gutter extensions. But I put a 7/8 inch rubber tip ( the ones used for chair legs, crutches)
over the drain extension . tape it in place them install the bag they provide.
Look over your RV for protrusions that could damage the cover and insulate the cover from them.
To get the cover to last these are some of the precautions needed.
To store the cover I purchased a large Rubber Maid tub with cover. Keeps it clean and safe from storage damage.
Yes it is extra work to do this but it protects your RV and when you uncover your RV it is clean and has no fading or weather damage.
G. Reed - temccarthy1ExplorerI recommend ADCO. Read a lot of reviews on Amazon before buying one last year. They have been in business 60 years just making RV covers so they are doing something right! Have had it for 1 winter and performed well. Like the vents and double zippers that allow me to get into camper without removing. Has many straps underneath to secure and 2 on each end. For $250, I will be happy to get 3-4 years out of it but I assure you, they keep your camper looking new with no fading of finish and decals as well as keeping ice, rain and snow off it!
- TequilaExplorercalmark is the best, they also custom make them with things like zippers on either side of your slide.
- OasisbobExplorerI amsurprised to see positive posts on Adco. Ours had a small rip that spread the first year and it had alot of wind flap. We went to a large silver tarp with quart jugs to eliminate wind flap.We found a tarp surprsingly close to size and used it until we got the metal canopy. In short tarp is more cost effective and durable IHO
- jfkmkExplorerI've used anAdco cover for four years now (putting it on this weekend for year 5) and it shows no sign of wear. Pad sharp edges, put the cover on snug and you'll have no problems. My trailer looks brand new, no fading of decals, oxidation. It takes me 20 minutes to put it on.
- Mr__CamperExplorerWe had a custom fit ADCO and it lasted longer than the 10 Year old Prowler we had. We gave it to a neighbor and they are still using it. We bought another custom ADCO for our Open Range and after two years it's still looks like a brand new one. We store it in a large bin when it's not being used. It takes about 20-25 minutes to put it on and about 20 minutes to take it off and fold and store it.
- Dick_BExplorerFor previous posts on this popular subject search this Forum in the TT section for `rv cover' where you will find my recommendation.
44,056 PostsLatest Activity: Jan 19, 2025
