mradExplorer IIMar 27, 2021Which E rated ties have the most weight capacity?I will need to be replacing the tires on my 1 ton. I have noticed there is a bit of a difference in tire weight capacity ratings. I currently have Firestone Transforce that has 3680 lbs per tire. Whil...Show More
8_1_VanExplorerMar 29, 2021All E rated tires of the same size should have the same weight capacity.Here is a 4,080 lb capacity tire :
Related ContentRam 1500 Towing CapacityTowing capacity vs max cargo weight ratingTrailer weight capacity/axle weight capacityDry tongue weight versus fully loadedToyhauler weight vs truck capacity
