Francesca_Knowl
Feb 28, 2014Explorer
Towing as close to level as possible is definitely best, especially with a dual axle trailer. You want the load on those tires/axles to be as evenly split as possible.
You're right about tongue weight math- weigh the truck separately, then while it's hooked up (trailer off scale). Difference between those two numbers will be tongue weight.
I think it's best to do this with W/D disconnected just so you get "real" tongue weight numbers before the weight gets "distributed". I may well be wrong about that- and I'm sure that if so, someone will be along with a correction.
