sgfrye
Jun 07, 2018Explorer
Terryallan wrote:SoonerWing03 wrote:
Also, more than looking at the GVWR I am looking at the Dry Weight and adding 1,500 lbs to come up with the under 6,000. Simply because I have seen some with a dry weight of 4,100 and GVWR of 7,000. The GVWR would put it out of my range but in reality there is no way that I would load 2,900 lbs in it. Hopefully that is logical,
Honestly you are right. My dry weight is 4811lb. My GVWR is 7500lb. A totally useless number. It will NEVER weight even close to that. right now it is close to 6000lb. So if you find what you want that you can add 1500lb to and come in under 6000. Good to go. In truth. 1500 is prolly more than you will load.
Only reason I ever look at the GVWR is to make sure the TT has enough carry capacity to carry 1500lb. Not all have a large carrying capacity. Some will have a dry weight of say 4000, and a GVWR of 5000. not enough.
excellent post here.
the adding 1500lbs to dry weight is accurate for us. 6300 dry factory weight, 7500lbs ready to camp on cat scales
kinda tough to test tow a TT to cat scales to get accurate rate. adding 1500lbs is a good general rule to look at TT's window shopping
44,068 PostsLatest Activity: Jun 01, 2026
